Monadnoc Posted May 18, 2012 Share Posted May 18, 2012 I posted this in the "General" area of the Forum but didn't get any responses, so I thought maybe it was better suited here ... here is my problem: I am trying to create a Custom Tool using the Custom Tool/Attribute menu command that will draw a wall in a specific class and layer but also of a specific Wall Style. The command doesn't seem to address Wall Styles, in fact it seems to automatically draw only Unstyled walls. I think the answer would be to manually insert a line in the script setting the Wall Style, but I haven't used Vectorscript in about 15 years. I've tried to figure it out with no luck. Here is the script the tool automatically creates. It seems to me that right after the line "CallTool(-208);" another line setting/calling the Wall Style should/could be inserted, but nothing i've tried works. I created a Custom Modification script to get the Wall Style, it says "EditProperties((WST='Building Wall'));" (without the quotes) so I tried inserting "SetWallStyle((WST='Building Wall'));" but got an error. Any help would be greatly appreciated. Thanks. Monadnoc Procedure CustTool; VAR Name:STRING; Result:BOOLEAN; BEGIN PushAttrs; Result := DeleteAllComponents(nil); Result := InsertNewComponent(nil, 1, 1'0", 1, 2, 2, 2, 2); Result := SetComponentName(nil, 1, ''); Result := SetComponentClass(nil, 1, 0); Result := SetComponentFillColors(nil, 1, 257, 257); Result := SetComponentPenColors(nil, 1, 257, 256, 257, 256); Result := SetComponentUseFillClassAttr(nil, 1, FALSE); Result := SetComponentUsePenClassAttr(nil, 1, FALSE, FALSE); PenSize(2); PenPat(2); SetZVals(0", 0"); FillBack(1278); FillFore(257); FillPat(1); Result:= SetDefaultBeginningMarker(0, 15, 0.125000, 0.000000, 0, 0.000000, FALSE); Result:= SetDefaultEndMarker(0, 15, 0.125000, 0.000000, 0, 0.000000, FALSE); PenPat(2); PenSize(2); NameClass('Architecture-First Floor'); Layer('Building and Boundary Layer'); PenBack(256); PenFore(257); PenPat(2); CallTool(-208); PopAttrs; END; Run(CustTool); Quote Link to comment
Miguel Barrera Posted May 18, 2012 Share Posted May 18, 2012 Looking at the definition of the function, there are missing parameters in your code: FUNCTION SetWallStyle( theWall :HANDLE; wallStyle :STRING; selectedOffDistance :REAL; replacingOffDistance :REAL) : BOOLEAN; It should be something like: .... CallTool(-208); result:= SetWallStyle(LNewObj,'Building Wall',0,0); .... Quote Link to comment
Monadnoc Posted May 18, 2012 Author Share Posted May 18, 2012 Thanks for your response. I tried pasting in the line result:= SetWallStyle(LNewObj,'Building Wall',0,0); right after the CallTool(-208); line like you have it, but it doesn't seem to work. The Walls it draws still come out as unstyled. I am very rusty at VS so maybe I am misunderstanding something. All I did was add that line. Do I need to add anything else? Thanks. Monadnoc Quote Link to comment
Monadnoc Posted May 22, 2012 Author Share Posted May 22, 2012 Any other suggestions on how to get this to work? Any help would be much appreciated. Thanks. Monadnoc Quote Link to comment
Sean R. Posted April 14, 2023 Share Posted April 14, 2023 Procedure CustTool; VAR Name:STRING; Result:BOOLEAN; BEGIN PushAttrs; Result:= SetWallStyle(LNewObj,'Building Wall',0,0); PenSize(2); PenPatN(2); SetZVals(0", 0"); FillBack(256); FillFore(1252); FillPat(1); Result:= SetDefaultBeginningMarker(0, 15, 0.125000, 0.000000, 0, 0.000000, FALSE); Result:= SetDefaultEndMarker(0, 15, 0.125000, 0.000000, 0, 0.000000, FALSE); PenSize(2); NameClass('House-Remaining'); Layer('House Walls'); PenBack(256); PenFore(257); PenPatN(2); TextFont(28); TextJust(1); TextSize(12); TextSpace(2); TextFace([]); CallTool(-208); PopAttrs; END; Run(CustTool); I added the line "Result:= SetWallStyle(LNewObj,'Building Wall',0,0);" and deleted the lines " Result := DeleteAllComponents(nil); Result := InsertNewComponentN(nil, 1, 6", 5, 0, 0, 2, 2); Result := SetComponentName(nil, 1, '2D/3D Wall Existing'); Result := SetComponentClass(nil, 1, 0); Result := SetComponentFillColors(nil, 1, 257, 256); Result := SetComponentPenColors(nil, 1, 257, 256, 257, 256); Result := SetComponentUseFillClassAttr(nil, 1, FALSE); Result := SetComponentUsePenClassAttr(nil, 1, FALSE, FALSE); " the deleted line where created by the custom tool command Quote Link to comment
