Joey Parsonson Posted May 18, 2012 Share Posted May 18, 2012 To whom it may concern @ Nemetschek, I am a current Vectorworks 2011 user and would like to suggest adding text settings to the edit class dialog which would allow you to assign text to a class then edit all text using the edit class dialog box to change text style, size colour etc. The reason being is when i use the windoor tool for ID display, the settings are different from a door as opposed to a window or even a window/door combo & sometimes i have to scale the ID display textfor each type of windoor object. It would be alot faster to edit this with one click in the WD-ID class edit dialog box. Another alternative would be to have a scale ID text setting in the OIP when a windoor object/s are selected Please take a little time to give this some thought. This text setting could be used for a hole lot of other tools aswell if it was a class setting. Regards Joey Parsonson Quote Link to comment
