Christiaan Posted May 8, 2012 Share Posted May 8, 2012 Has anyone actually managed to obtain a finished render of, say, an A1 sheet of elevations set to custom Renderworks, all options High Quality and 300 dpi? All I keep getting is an email telling me it failed to process my file and I should "rest assured an experienced team of winged monkeys has been dispatched to fix the problem", along with a link to bunch of reasons why it might of failed but not the reason why mine did fail: http://kbase.vectorworks.net/questions/997/Cloud+Job+File+Failure Quote Link to comment
Peter van der Elst Posted May 9, 2012 Share Posted May 9, 2012 Maybe because the rendering is so slow it takes more then 24 hours? Have you tried lowering the settings? Quote Link to comment
Christiaan Posted May 9, 2012 Author Share Posted May 9, 2012 The file I was testing with only had one sheet of elevations and some plans. And the elevations only took an hour or so to render on an iMac. I was thinking maybe the servers were being hammered after the Europe release, but it's not like a webpage... they have a queuing system. Quote Link to comment
michaelk Posted May 9, 2012 Share Posted May 9, 2012 Christiaan I've seen that in the US, too. It feels like a 1.0 release and they are stomping on bugs as they find them. I don't know this for sure, but - from my experience with it - it appears that there have already been one or two updates. I'm getting the monkeys message less often now than I did when it launched. I've been wondering about dpi as well. I haven't tried Nomad on a original iPad or iPad2, but the render time on an iPad "3" is very long with dpi set at 150. Perhaps it was tested on the earlier machines and the slow draw time is because of the quadrupling of the number of pixels. mk Quote Link to comment
Donne Martin Posted May 9, 2012 Share Posted May 9, 2012 Hi Christiaan, Our monkeys are sifting through server logs and crash reports to investigate what caused your jobs to fail. It would be very helpful if you could send me one or two sample files (dmartin@vectorworks.net). Just a quick note, our systems are reporting a ~95% success rate with all jobs so far, slightly less after your files hit our servers As michaelk mentioned we are actively monitoring the system and fixing bugs as they come up. I'll let you know what we find out about your jobs. Regards, Donne Quote Link to comment
Christiaan Posted May 9, 2012 Author Share Posted May 9, 2012 Hehe, well I dont know whether to be embarrassed or impressed that my files are lowering your stats. I'll send em through to you shortly. Thanks for the update. Quote Link to comment
michaelk Posted May 9, 2012 Share Posted May 9, 2012 Donne Thanks for for the insight. Any suggestions for speeding up iPad(3) rendering time? mk Quote Link to comment
Jeffrey W Ouellette Posted May 10, 2012 Share Posted May 10, 2012 michael, The Nomad application on the iPad doesn't "render" anything in the file itself. It is just a PDF viewer. Large PDFs, with sheets that have large, complex, or high res renderings take a little while longer for the viewer to cache to the screen. Once there, they should become a little more responsive in panning and zooming. Not fluid, but better. You have to accept that the iPad has a limited amount of RAM and VRAM, two things that have a direct affect on the "speed" of viewing large PDFs. The same file on a desktop or laptop will be more responsive. Quote Link to comment
Christiaan Posted May 10, 2012 Author Share Posted May 10, 2012 You have to accept that the iPad has a limited amount of RAM and VRAM, two things that have a direct affect on the "speed" of viewing large PDFs. The same file on a desktop or laptop will be more responsive. ...wouldn't it be better as UX designers to accept that the iPad isn't designed for such large PDFs and use a different method for displaying such sheets on an iPad? Quote Link to comment
Kevin McAllister Posted May 10, 2012 Share Posted May 10, 2012 I would tend to agree with Christian. I used Vectorworks Cloud Services for a few days before I went back to my old workflow. My previous workflow used iBooks as my viewer for self generated PDF files. It never has trouble with my PDF files. The PDF generator on Vectorworks Cloud Services is actually custom. It doesn't generate identical PDFs to Vectorworks (different bookmarking is one anomaly). Perhaps it could be made to "flatten" the PDFs or optimize them in some way. This has long been a wish list item for the desktop version of Vectorworks. Kevin Quote Link to comment
Donne Martin Posted May 10, 2012 Share Posted May 10, 2012 Hi Michael, When Nomad opens a file there are two steps: 1) If the file is not cached on the device, it will first download the file. We've seen some files upwards of 20 MB depending on quality settings and DPI--these could take awhile to load over wifi or 3G. Note after the file is downloaded, Nomad caches this file for offline support. 2) Once the file has been downloaded to the device, it is then opened and rendered/displayed. A good test of performance is to try the same file on iBooks and compare the speed. Although our tests indicate performance is similar for both applications, we are continually working to improve the app. If you find a considerable difference between Nomad and iBooks, please send us the file to investigate. Thanks Donne dmartin@vectorworks.net Quote Link to comment
Donne Martin Posted May 10, 2012 Share Posted May 10, 2012 Hi Kevin, Could you send me the PDF files you see a speed difference in Nomad vs iBook? As I mentioned in the post above our tests indicate similar performance based on our set of benchmark files. We'd love to see where we can improve and your files could be very helpful. >It doesn't generate identical PDFs to Vectorworks (different bookmarking is one anomaly) I don't believe we've encountered this situation. A test file would be very helpful in tracking this down. Thanks in advance for your help. Regards Donne dmartin@vectorworks.net Quote Link to comment
Chris D Posted May 10, 2012 Share Posted May 10, 2012 Hehe, well I dont know whether to be embarrassed or impressed that my files are lowering your stats. :grin: Quote Link to comment
Donne Martin Posted May 11, 2012 Share Posted May 11, 2012 Hi Christiaan, We have discovered the failing jobs are from out of memory errors during PDF export while rendering viewports, both on our cloud machines and on our in-house QA machines. >A1 sheet of elevations set to custom Renderworks, all options High Quality and 300 dpi >iMac 3.4 GHz Intel Core i7?12 GB RAM?2GB AMD Radeon HD 6970M To help keep everyone in the loop: Based on our off-list discussions you mentioned you are able to run a full export on your [beastly!] machine but occasionally receive out of memory errors and crashes on save. We have been unsuccessful on both our cloud and on our in-house QA machines thus far. Vectorworks in the cloud is currently 32-bit like its desktop counterpart, so if the file cannot be processed locally due to out of memory issues, the cloud will see the same result. To answer your off-list question, our machines on the cloud are Windows-based, as Apple does not allow licensing for cloud-based Mac machines. However, we have a mix of 50/50 Win and Mac computers in-house that we use for testing and development. QA will be attempting DPI?s of less than 300 and different 3D conversion resolutions to see if either of these settings would allow your files to be processed. We are considering an option to send jobs to the cloud as either "printing quality" (300 DPI) or "viewing quality" (less than 300 DPI). For the latter we are trying to determine an appropriate DPI threshold as 300 seems overkill for mobile viewing. We?ll run some additional tests to see where we can improve. Thanks for the feedback! Regards, Donne Quote Link to comment
Kevin McAllister Posted May 11, 2012 Share Posted May 11, 2012 Hi Donne, I had a follow up email from someone in your department. I sent them an example of what I was seeing and some other feedback based on my Cloud experiences. Thank you, Kevin Quote Link to comment
Kevin McAllister Posted May 11, 2012 Share Posted May 11, 2012 I love this. Real world files are a great test for real world software :-) Quote Link to comment
Christiaan Posted May 11, 2012 Author Share Posted May 11, 2012 Appreciate the openness Donne, thanks. Sounds to me like 64-bit is going to be key to making this work. I'm guessing v2013 has something to say about that? Quote Link to comment
Chris D Posted May 14, 2012 Share Posted May 14, 2012 I'm guessing v2013 has something to say about that? Nice try. Quote Link to comment
Christiaan Posted May 14, 2012 Author Share Posted May 14, 2012 Yeah, wishful thinking no doubt. Quote Link to comment
Donne Martin Posted May 15, 2012 Share Posted May 15, 2012 Kevin, Thanks for your input, we've confirmed there is a difference in the way PDF files are exported on the Mac versus on Windows, we'll look into a fix. Christiaan, >I'm guessing v2013 has something to say about that? Nice try Regards, Donne Quote Link to comment
Christiaan Posted July 2, 2012 Author Share Posted July 2, 2012 Based on our off-list discussions you mentioned you are able to run a full export on your [beastly!] machine but occasionally receive out of memory errors and crashes on save. We have been unsuccessful on both our cloud and on our in-house QA machines thus far. Donne, has there been any progress on this? I've been trying now and again to render the same files with no luck. Our machines aren't that beastly you know. 3.4 GHz Intel Core i7 iMacs with 12 GB RAM and 2 GB AMD Radeon HD 6970M graphics. They're top of the range for their class but they're compact desktops really. They don't come close to top of the range server or desktop class machines. Quote Link to comment
Christiaan Posted October 23, 2012 Author Share Posted October 23, 2012 So is there any strategy going forward to actually make cloud rendering work or is it always going to choke on our files? How much of that percentage of successful renders are actually Renderworks elevation drawings as opposed to plans and other line drawings? I have a bunch of people (incl. people on your beta program) who have messaged or emailed me privately to point out it's never worked for them either. Quote Link to comment
Chris D Posted October 24, 2012 Share Posted October 24, 2012 This is why VECTORworks needs to have VECTOR based elevations and sections that can be printed without rendering to bitmaps. Why the heck are you having to render anything other than visuals? Quote Link to comment
Kevin McAllister Posted October 24, 2012 Share Posted October 24, 2012 This is why VECTORworks needs to have VECTOR based elevations and sections that can be printed without rendering to bitmaps. Why the heck are you having to render anything other than visuals? Yes, yes, yes. KM Quote Link to comment
Christiaan Posted September 24, 2013 Author Share Posted September 24, 2013 So is there any strategy going forward to actually make cloud rendering work or is it always going to choke on our files? Ugh, as of v2014 cloud rendering is still choking on our files. Quote Link to comment
