johnbolt Posted June 20, 2002 Share Posted June 20, 2002 What am I doing wrong? If I copy a detail and text from 9.5 to paste in 8.5, all the text is jumbled and rotated! If I convert an 8.5 wall with simple window or door to 9.5, the plug in dialog is not available to make changes. Mac 0S 9.2 on G4...... Quote Link to comment
Guest Posted June 21, 2002 Share Posted June 21, 2002 You should not copy objects from one version of VW to another version, otherwise it will com eout wrong in most cases. What you should do, is conver the VW 9 file to a VW 8 file by going to File>Export>Export as VW 8 file and save the file. THen open the file in VW 8, copy the information you want and paste it into the other VW 8 file. Quote Link to comment
