Christiaan
Dark windows and Renderworks backgrounds
Do you send them the actual VW Drawing or just renders of what you need?
If the Latter, Why not Export to PDF out of VW?
To reduce that file of say 22MB you open in GIMP2.0 and save as a JPEG or something similar
I then Print the image back to PDF to acuire a file of less than 500kb.
This might not sort out your halo problem as I also still have that at high quality renders. I did post about it.
One way to eliminate the halos is to render with anti-aliasing turned off. If doing this results in a blockier looking image, you could try rendering at a higher resolution (memory permitting) and, if needed, reduce the resolution in a good image editor. If you cannot render at a higher resolution, changing the exported image to a higher resolution using a good image editor can also soften the image.
Just some thoughts...
