kristynav 0 Posted May 3, 2012 Hi everyone, I've been trying to render my project, but it crushes after just a few seconds. It seems that when I render only a few objects, it's fine, but when I try to render most of my classes it crushes. Is it possible that my file is too large? It's about 330 MB, has around 120 classes and 3 layers. Is this normal for an interior design project? What can i do to reduce the size? Or is there any other problem? Please help. Thank you! Quote Share this post Link to post
cad@sggsa 0 Posted May 3, 2012 Hi Are there alot of curves involved and what textures are applied? What lighting have you added and what render Style are you using? Maybe post a Wireframe/openGL of the render view. Quote Share this post Link to post
kristynav 0 Posted May 3, 2012 Hi Carl, Thanks for your quick reply. Yes, there are a lot of curves. I used my own textures from jpegs, created new ones and also used some of the VW library ones. I have a few area lights, some spotlights and a directional light. I am still quiet new to VW so not sure what I'm doing wrong. Quote Share this post Link to post
cad@sggsa 0 Posted May 3, 2012 Good day Melady Sounds like you getting the hang of things though. Like I said: What render style/mode are you using for it to crash? can you do openGL? and post it here. [To post an image: switch to Full Reply Screen, click on File manager, browse file and add.] Due to all the curves you will need to tone it down on the rendering side. Reflective textures like Chrome on a round surface, like trussing, will not render if values are set too high. Maybe render at a lower DPI or edit texture to be less reflective or make curved surfaces less curved. Does the program just shut down or is there a "out of Memory" message? Quote Share this post Link to post
kristynav 0 Posted May 6, 2012 I have changed some of the textures (deleted some of the jpeg ones and used simpler ones instead) and it seems to work better. Before that I could't even render it on openGL, VW just shut down. Thanks for your help. Quote Share this post Link to post
Bob-H 1 Posted May 7, 2012 It could partially be the amount of RAM you have. For my MBPro, I've had hangups with Renderworks. With the recent drop in memory prices, I got for $70 two new 4GB chips for 8GB total, carefully installed them, and found that rendering is much faster now. Another thing to consider is to render with the sheet layer viewport only, and use it to turn off classes you don't need in that view. Finally, it is always helpful to purge unused resources, to keep the file size down. Quote Share this post Link to post
cad@sggsa 0 Posted May 7, 2012 This is why I asked if there was a message of some sort. I do not see why you would need more RAM just to do a simple render as you are on 4GB, 8GB would be best. Next Q: Have you tried doing a render with only VW open after a fresh restart? Interesting that you cant even do OpenGL. What grafix card do you have? Quote Share this post Link to post
kristynav 0 Posted May 7, 2012 I don't have a problem with the memory. I have about 415 GB free on my HD and have NVIDIA GeForce 9400M 256 MB card. I tried to restart and had only VW opened but didn't help. I do use only the classes that are in the viewport and purge regularly. I turned of some lights as well as used simpler textures and it works ok now. Quote Share this post Link to post
cad@sggsa 0 Posted May 7, 2012 Still very strange that VW will not Render in OpenGL... So now you can render, please give us a look see of what you were trying to render Quote Share this post Link to post
grant_PD 253 Posted May 7, 2012 256 mb of Vram IS a memory problem. And 4mb of RAM IS a memory problem. Your hard drive space doesn't mean anything when it comes to rendering. Quote Share this post Link to post
Pat Stanford 1,546 Posted May 7, 2012 VW2012 requires a minimum of 512mb of Vram. http://kbase.vectorworks.net/questions/929/Vectorworks+2012+System+Recommendations Quote Share this post Link to post
cad@sggsa 0 Posted May 8, 2012 256 mb of Vram IS a memory problem. And 4mb of RAM IS a memory problem. Your hard drive space doesn't mean anything when it comes to rendering. Aha! I was right I missed that bit of 256mb. That is like entry level and VW does like upgrades Did not think 4GB would be a problem, now we know Thanks Grant. Quote Share this post Link to post
kristynav 0 Posted May 8, 2012 It renders, but it's very slow and shuts down quiet often. So is that it? I need better graphics card and RAM? Thanks guys. Quote Share this post Link to post
grant_PD 253 Posted May 8, 2012 No, that's just your hardware issues. There's no way of really knowing what's going on and bogging down your file. It could be bad geometry, something with your lights... Rendering is not a plug n play process. There's often a lot of intuition involved in getting your rendering speed up and the stress on your system down. Quote Share this post Link to post
cad@sggsa 0 Posted May 9, 2012 Process of elimination... Textures - toned down. Graphics+RAM - upgrade. Overall drawing and render settings. Maybe there is one symbol like an imported light that is needing unnecesary generation. Quote Share this post Link to post
