mpkeane Posted April 24, 2012 Share Posted April 24, 2012 I am working on a MacBookPro with OS 10.6.8 and VW 2010. Is there a function in VW to apply a "curly brackets" to a design? Not as a part of text, but to link a comment with a group of objects, or point towards a section of a drawing. (These are curly brackets >> http://en.wikipedia.org/wiki/Bracket#Curly_brackets_.7B_.7D) Marc Quote Link to comment
VincentCuclair Posted April 24, 2012 Share Posted April 24, 2012 (edited) You need to go to System Preferences>International>Input Sources and check the box at the top (don't know what it's called on the English version, I'm on the Swedish version). You then get the symbols options at the top right of your screen from which you can choose and insert a symbol of choice. I don't really know what you mean by 'not as part of a text', it is text so either you add it as text or if you want it as a graphic you add it as text then run True Type to Polyline. Edited April 24, 2012 by Vincent C Quote Link to comment
