Curly Brackets
You need to go to System Preferences>International>Input Sources and check the box at the top (don't know what it's called on the English version, I'm on the Swedish version). You then get the symbols options at the top right of your screen from which you can choose and insert a symbol of choice.
I don't really know what you mean by 'not as part of a text', it is text so either you add it as text or if you want it as a graphic you add it as text then run True Type to Polyline.
Edited by Vincent C
