Title Block: ability to display current revision letter/number separately
Christiaan
9 answers to this question
Does anyone know if this problem has been sorted out yet. I have had to manually put the current revision in each sheet since I started using VW - and it is a real pain.
It is really frustrating because it must just simply be a record field with we should be able to reference.
It is also interesting that you can only have one instance on the :rNo or any other revision data on a sheet - Why???
Hi Kevin,
June first I'll announce my website containing custom Vectorworks2015 plug-ins.
You will be very interested in the revision manager.
It is a separate dialog that allows you to control all revision and issue data.
Some of the key features that extend the default behaviour:
  • You can add/edit revisions/issues on multiple drawingborders at once.
  • You can assign the last revision letter/number + date to titleblock fields as you request.
  • You can control the date string giving you a lot of options.
  • You can use the global mode which only keeps one set of data used on all drawingborders.
The following image is a screenshot of how the dialog looks like.
Edited by hippothamus
