graham Posted June 17, 2002 Share Posted June 17, 2002 I have a drawing that I am working and the attribures are locked. I have looked at every preference that I can find and I can't unlock them. I can change the values in the attribute pallet, but when I select a new tool it still has the old values. I can work around this by selecting the object and changing the attributes but this not the way VW is to work. I sure could use some help. Quote Link to comment
P Retondo Posted June 17, 2002 Share Posted June 17, 2002 Do the attribute values revert when you select the tool, or right after you use it? If the latter, you probably have an object selected somewhere when you changed the attributes (check your info palette to see). Only if nothing is selected do changes to the attribute palette affect the status of defaults. Or, it could be a problem I know nothing about . . . BTW, it helps the tech support folks if you supply your system specs (VW version, OS, processor). [ 06-17-2002: Message edited by: P Retondo ] Quote Link to comment
ionw Posted June 17, 2002 Share Posted June 17, 2002 another possibility is that your active class has use at creation which would force it too... Quote Link to comment
