How do I ?Lock? mu custom PIO to make it uneditable
The short answer is to look in the VS Language guide, which is part of the help app:
To encrypt a plug-in:
1.Select Tools > Scripts > VectorScript Plug-in Editor. In the VectorScript Plug-in Editor, select the plug-in to be protected from the editor list.
2.Use the following key combination, pressing the keys simultaneously:
Macintosh
Caps Lock+Shift+Option+Command
Windows
Shift+Ctrl+Alt
3.Click the Script button in the Editor. Confirm twice that the plug-in should be protected.
One large thing to note -- encryption cannot be reversed, so make sure to duplicate your plug-in before you encrypt.
If you use include files for your code, files with the .px extension will be pulled in to your plug-in while files with the .vss extension wil still be needed if you copy the plug-in to another installation.
My personal workflow takes advantage of the batchencryption library that's included in the SDK. It allows you to write a VS that encrypts plug-ins, and you can point to a plug-in that is outside of your plug-ins folder (eg a duplicate copy). I've developed an Automator script to handle the whole thing and guarantee I'm never accidentally locking an original copy. Some day I'll have time to share the process.
-Josh
Thank you, that is excellent. Just tested, it works exactly as you describe.
(Honestly, I searched the Language Guide repeatedly, I clearly missed these instructions. I did find EncryptVSPluginFilePath as you mention http://developer.vectorworks.net/index.php?title=VCOM:VectorWorks:ISDK::EncryptVSPluginFilePath and was on the verge of attempting that process. I really appreciate you lending a different set of eyes to guide me along!)
PS. looking forward to that automator workflow! :)
  • 2 years later...
