Kizza Posted April 11, 2012 Share Posted April 11, 2012 I have two buildings on the one site. I need some drawings to show one building and others to show both. Is it best to: 1) Draw each building on a separate design layer 2) One DL but put one building in a separate class? Quote Link to comment
Chris D Posted April 11, 2012 Share Posted April 11, 2012 As long as the buildings are separate, why can't you just use section viewports to set up your elevations, and use viewport crops to show however much you like...one building or both as required? i.e. don't distinguish by either class or layer...just by crop Quote Link to comment
Christiaan Posted April 11, 2012 Share Posted April 11, 2012 (edited) You might like to put them in separate files. There are various reasons VW pushes you toward this way of doing things. One of them is the ability to control the storey heights separately for each building. You can then create viewports of each building in the same files or you can reference them all into one file, build a site model with and then create any view you like. Edited April 11, 2012 by Christiaan Quote Link to comment
Kizza Posted April 11, 2012 Author Share Posted April 11, 2012 (edited) Chris D: I have a site plan - my drawings need to show the whole site, but I need to show options,i.e. drawing to show the footprint of one building and another drawing without that building. Same with the floorplans. Project is a remodel of an existing dwelling with proposed two design options for an external granny flat. Christiaan: I've yet to try this approach but it seems to be an accepted workflow option. I'm not sure why we can't just create the topography to the standard datum (AHD in Aus) and have all our levels also to AHD. Creating topography in one file, and referencing a building from another file, without using the same datum seems nonsense to me. Edited April 11, 2012 by Kizza Quote Link to comment
mar schrammeyer Posted April 11, 2012 Share Posted April 11, 2012 I would use your first option Quote Link to comment
Kizza Posted April 12, 2012 Author Share Posted April 12, 2012 thanks, thats what I suspected. Quote Link to comment
