VincentCuclair Posted April 10, 2012 Share Posted April 10, 2012 (edited) I would like to have added functionality in the form of: 1. Grids in multiple directions at different angles etc. 2. Interactive dimensioning (like in associative dimensions). 3. Some kind of reference/connection to alternative co-ordinate systems....georeferencing....stake tools etc. 4. Different bubble 'shapes' ie. Swedish building standards make use of both bubbles and parallellograms for primary resp. secondary grids. Edited April 11, 2012 by Vincent C Quote Link to comment
0 Chris D Posted April 11, 2012 Share Posted April 11, 2012 Yes Yes Yes Yes Need I say more? Quote Link to comment
0 Chris D Posted April 11, 2012 Share Posted April 11, 2012 Need I say more? Oh, go on then. 5. Grids that work in section/elevation view http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=34031&Number=167774 So that the grid and storey-height setup are linked into a 3D grid. I should be able to see storey-height grid lines in any section viewport AND I should also be able to see the X or Y grids superimposed over these views too if I'm looking across them. Quote Link to comment
0 Chris D Posted April 11, 2012 Share Posted April 11, 2012 6. Scheduling of objects by grid position If it's an intelligent grid, let's see some intelligent uses, like reporting symbol positions by storey and grid reference. Quote Link to comment
0 Chris D Posted April 11, 2012 Share Posted April 11, 2012 Why is the Grid Bubble tool unrelated to the Grid Rectangular tool? Any why are the Snap Grid and Reference Grid unrelated to both? Is this just to confuse new users (and old ones...)....? Quote Link to comment
0 VincentCuclair Posted April 11, 2012 Author Share Posted April 11, 2012 Yes, of-course Yes same line of thought..... Quote Link to comment
0 Christiaan Posted April 11, 2012 Share Posted April 11, 2012 What about the requests on this thread. Have we got all of them yet? http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=84229 Quote Link to comment
0 Chris D Posted April 11, 2012 Share Posted April 11, 2012 What about the requests on this thread. Have we got all of them yet? http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=84229 Yes we'd like them. Don't think we've got them.. Quote Link to comment
0 VincentCuclair Posted April 11, 2012 Author Share Posted April 11, 2012 In short quite a lot of improvement needed, just to up the pressure ArchiCAD has had all of this in at least the last 3 versions....... Quote Link to comment
0 Chris D Posted April 12, 2012 Share Posted April 12, 2012 7. Lock Grid Position The most important thing about a building grid is that it is an immoveable reference for the other building elements. The fact that you can't lock the grid position (like you can with a DLVP for instance) means it isn't foolproof. Sure, you can lock the object, but then you can't get to the settings without unlocking it, so a "Lock Position" toggle on the OIP is required that will lock the grid so that it can't be dragged accidentally. Of course, accidental dragging is not something that should be available in a professional CAD/BIM application as I've said before - there should be a global preference to turn it off: See Robust Foolproofing Quote Link to comment
0 VincentCuclair Posted June 1, 2012 Author Share Posted June 1, 2012 (edited) How does one fix something like this using the grid bubble tool without getting sore fingers from punching numbers on the number pad and without getting a headache from all the maths? Edited June 1, 2012 by Vincent C Quote Link to comment
0 VincentCuclair Posted June 1, 2012 Author Share Posted June 1, 2012 Oh and an option for suffixes too! Quote Link to comment
VincentCuclair
Edited by Vincent CLink to comment
11 answers to this question
