VW Plant Database Not Locating My Favorites with Pictures
Over the years I have painstakingly built up "my favorites" plant lists (i.e. trees, perennials, shrubs, etc.)in VW Plants Database. I have these (.txt) files saved in several locations but when I try to use search>favorite>shrubs in VW Plants...it says it no records match and gives me an option to modify search. This used to be the function I used the most to flip through all my favorite plants with photos.
However, if I'm in VW on a design layer and editing a plant (edit definition>get plant data) I can pull up my various favorites lists ok but I don't have the benefit fo the VW Plants>Plant Data with my photos.
I don't think I have a very good handle on what files hold the pictures I attached and what folder needs to be referenced. Can anyone help? and please tell me my data isn't lost.
Thanks in advance
Vector Works 2008 SP3 (Build 88670)ck in touch - Landmark, Renderworks
Windows XP Pro - SP3
NVIDIA Quadro FX 2700M
Intel ® Core 2 Duo CPU
2.53 GHz, 2.99 GB RAM
Edited by stmlandplan
Hi
Your data with photos can only be viewed using the Vectorworks Plant Database, which is separate application within Filemaker.
When you create a text list from the Vectorworks Plant Database, Vectorworks Landmark can read that text file and use it to attach the data to your plant symbols. But not the images you have stored in the database. The text files hold just that - text.
Hope that helps.
Your data is stored in a file called VW Plants.USR.
However, you won't find it under c:\Program Files\Vectorworks 2008. This is the original file, as installed. When you make changes to it, the modified file is stored in the following folder:
C:\Users\UserName\AppData\Roaming\Nemetschek\VectorWorks\2008\Plant Database\VW Plants.
I don't know why your database would lose this data... but presumably you have a recent backup that you can restore if it really is lost?
All the best
I don't have anything at this address C:\Users\UserName\AppData\Roaming\Nemetschek....
I do have C:\Program Files\VectorWorks 2008\Plant Database\VW Plants\...
So I created the location you defined and copied my latest USR file into it and then directed it under "Choose VW Plants" to go to that location. Even though it shows it pulling in my favorites (as it scrolls when opening VW Plant Database) it still doesn't seem to have any of my plants with pictures.
It must have cooupted or lost something. Can I re-install VW Plants Database without re-installing the whole program or would this even help?
BTW my USR file is 84MB so I know the info is in there.
