[Vectorscript] passing dynarrays to procedures/functions.
Dieter @ DWorks
The inability of passing dynarrays to procedures/functions is making some scripts extremely difficult. If we could do this, it would be easier to write own subprocedures.
As an example, the IntersectSurface function returns only the first object. I wanted to make my own procedure to always return all objects, but because I can't know how many there will be returned, I can't make the procedure. I first did return a group, but this give too many problems.
2 answers to this question
You can pass dynarrays to procedures & functions after you allocate the size of the array.
I usually create a structure for an object and then declare a dynarray of the structure so I can have a list of the objects.
I know this is double work but you have to create a function that will count the object total first, allocate the array, and then pass the dynarray to a function for further processing of the list of objects.
That's what I'm doing now. It was exaclty my point that I don't want to allocate/count first before.
