3D landscape
Hakan
Well, you need to convert those 2D shapes into 3D, but you want to retain the 2D. I would suggest you use Landmark > Objects from Polyline to convert your 2D shapes to Hardscapes, Landscape Areas and Walls. Each of these will have a 2D and 3D component and can be set at any Z value relative to the design layer.
To create a mesh, you need levels measured on site, in a 3D format, which you can import and then create a site model.
I hope that this will help you get started, but what you have asked is really quite a huge question and not something that can be answered in a quick forum post... But I do hope it helps you to get started.
  • 1 month later...
