seasdes Posted March 17, 2012 Share Posted March 17, 2012 My Standards Palette has disappeared and will not reappear by selecting'Window > Palettes > Standards. Does anyone know how to get it to reappear? Walter VW Architect 2012 SP2 W7 Home Premium Quote Link to comment
mike m oz Posted March 17, 2012 Share Posted March 17, 2012 Reselect the Workspace: Tools/workspaces/Architect Quote Link to comment
seasdes Posted March 17, 2012 Author Share Posted March 17, 2012 I tried that and the problem remains. Walter Quote Link to comment
Pat Stanford Posted March 17, 2012 Share Posted March 17, 2012 Try resetting your monitor to a smaller resolution then back. Quote Link to comment
seasdes Posted March 17, 2012 Author Share Posted March 17, 2012 Just tried that Pat and no change. When I select the Palette it does not stick as an arrow does not show against the Standards Palette. It works OK when I select / deselect other Palettes. Walter Quote Link to comment
mike m oz Posted March 17, 2012 Share Posted March 17, 2012 I gave you bad advice before Walter - apologies for that. The Standards palette and its Pen tools are part of the local customisation by Ozcad and therefore will only appear in the Ozcad defined Workspaces. Therefore you need to select one of the Workspaces with ANZ or AUS at the end. Quote Link to comment
seasdes Posted March 17, 2012 Author Share Posted March 17, 2012 Its Ok Mike I followed your advice and selected Architect ANZ. However the tick does not stick next to the Standards Palette. Walter Quote Link to comment
mike m oz Posted March 17, 2012 Share Posted March 17, 2012 Try resetting Vw's preferences. If that doesn't fix it delete your User folder. This will force Vw to create a new one. If neither of those steps fix it you will probably have to do a reinstall. Before trying either of the last two make sure you make copies of any personal library files and the like. Quote Link to comment
