billtheia Posted March 8, 2012 Share Posted March 8, 2012 It seems like VW2012 is drawing and extra line at window and door jambs and I can't seem to get rid of them. If I create a SLVP and override the line color of walls, windows & doors, a black line remains at jambs. See attached pic and vwx file. My engineer has also had trouble with these lines in my DWG exports. Has anyone else out there experienced this? Can someone help me? Thanks. Quote Link to comment
michaelk Posted March 8, 2012 Share Posted March 8, 2012 I'm pretty sure that using wall styles will fix this. I just tried it with 3 components and that line wasn't a problem. mk Quote Link to comment
billtheia Posted March 8, 2012 Author Share Posted March 8, 2012 For me, the problem still exists when I use wall styles. Quote Link to comment
HAUSrucker Posted March 15, 2012 Share Posted March 15, 2012 for me to - why vw does?t clear these bugs? if i have a wall with one component -> i get this line with two component -> everything is quite fine grrrr Quote Link to comment
Mitch Brooks Posted March 15, 2012 Share Posted March 15, 2012 Check to see if in the Object Info panel, you have the window "break" set to "full break with caps". That might be the source of the extra line. Quote Link to comment
billtheia Posted March 16, 2012 Author Share Posted March 16, 2012 This setting seems to make no difference. Quote Link to comment
billtheia Posted June 30, 2012 Author Share Posted June 30, 2012 Any progress on this? I'm up to SP4 on VW2012 and it still seems to happen. Is there at least a work-around for this? Quote Link to comment
Kizza Posted June 30, 2012 Share Posted June 30, 2012 Toggle off then on "Use part line style" Does that fix it? Quote Link to comment
billtheia Posted July 2, 2012 Author Share Posted July 2, 2012 No. That doesn't fix it. This is really getting on my nerves. The problem didn't exist in previous versions of VW so VW effectively, broke door and windows. There have been 2 or 3 service packs released since this bug was identified and it's still not fixed. There isn't even a work-around. There are lots of things that I like about VW. Bug fixing and software consistency aren't among them. NVW, please fix this! Quote Link to comment
VincentCuclair Posted July 2, 2012 Share Posted July 2, 2012 (edited) Haven't found a solution but it seems to have something to do with components in walls, switch off wall components in the VP and the lines disappear. Edited July 2, 2012 by Vincent C Quote Link to comment
billtheia Posted July 2, 2012 Author Share Posted July 2, 2012 I don't use wall components but I do use wall styles. Quote Link to comment
VincentCuclair Posted July 3, 2012 Share Posted July 3, 2012 I don't use wall components but I do use wall styles. ....well then I did find a solution for you at least, otherwise I presume it's a bug because the line style is not overridden like everything else....... Quote Link to comment
