Craig D.S.
any object creation examples?
Greetings...
would there be any simple examples of creating Primitives or 2d objects to get started with.
I would like to start on some fun stuff first
starting with a ring of spheres or cones etc
My only scripting experience is with AutoCAD/TurboCAD VBA
Much Appreciated
Hey,
I recently made a small plugin object trough the plug-in editor(Tools=>scripts=>vw plugin editor).
Its ment to be a heat device drawn as a rectangle and some info in it.
I've added it to my post, use it as a plug in object or look at the code of it to give you a heads up..
PROCEDURE Radiator;
VAR
bc_ht,bc_wid,bc_height,bc_vermogen,i: REAL;
bc_fontsize,keuzes,height,numberpos : INTEGER;
objname,vermogen,bc_number: STRING;
bc_textposition,bc_numberposition: CHAR;
oh,rh,wh: HANDLE;
result,hidetext,shownumber: BOOLEAN;
BEGIN
{ retrieve custom object information }
result:= GetCustomObjectInfo(objname,oh,rh,wh);
{ if object information was successfully retrieved }
IF result THEN BEGIN
{ retrieve predefined parameter values }
bc_ht := PRWIDTH;
bc_wid := PRLENGTH;
bc_height := PRHEIGHT;
bc_vermogen := PVERMOGEN;
bc_textposition := PSHOW_VERMOGEN;
bc_numberposition := PSHOW_NUMBER;
bc_fontsize := PFONTSIZE;
bc_number := PNUMBER;
vermogen:=concat(bc_vermogen,' W');
{ retrieve user-defined parameter values }
{ draw }
i:=0";
PushAttrs;
FillPat(0);
{ draw rectangle with coordinates }
Rect(0,bc_ht,bc_wid,0);
{ draw text }
TextFont(GetFontID('Monaco'));
TextSize(bc_fontsize);
TextJust(2);
hidetext :=true;
shownumber :=true;
CASE bc_textposition OF
'O': height :=bc_ht+25;
'I': height :=bc_ht;
'H': hidetext :=false;
OTHERWISE height :=bc_ht+25;
END;
IF hidetext THEN BEGIN
TextOrigin(bc_wid/2,height);
BeginText;
vermogen
EndText;
END;
CASE bc_numberposition OF
'L': BEGIN numberpos :=3;height:=-5; END;
'R': BEGIN numberpos :=1;
height:=bc_wid+5;
END;
'H': shownumber :=false;
OTHERWISE BEGIN numberpos :=3;
height:=-5; END;
END;
IF shownumber THEN BEGIN
TextJust(numberpos);
TextOrigin(height,bc_ht);
BeginText;
bc_number
EndText;
END;
PopAttrs;
END;
END;
Run(Radiator);
