willofmaine Posted February 29, 2012 Share Posted February 29, 2012 When I send objects to the surface of my DTM (AEC > Terrain > Send to Surface) they seem to be going to the existing terrain, and not the proposed terrain, even though my model is set to display proposed only. How do I get objects to go to the proposed terrain?... Thanks! Will Quote Link to comment
JeremyLondonRMLA Posted June 7, 2017 Share Posted June 7, 2017 (edited) I've encountered the same problem over the years, and just found a solution. If the Site Model 2D Display is set to Existing Only or Proposed + Existing it seems to confuse the Send to Surface command, causing it to send some object types to the Existing surface, even when the 3D Display is set to Proposed. To resolve the issue, temporarily set the Site Model 2D Display to Proposed Only when sending objects to the surface, and then change it back again if required. Edited June 12, 2017 by JeremyLondonRMLA Quote Link to comment
AlanW Posted June 7, 2017 Share Posted June 7, 2017 (edited) You haven't taken a site model snapshot by the way and haven't put it on another design layer? Move your site model by an amount in y direction and see if another site model exists? Edited June 7, 2017 by Alan Woodwell Quote Link to comment
