ctrl key not for use now ?
Question... We used to be able to hold CTLR key down and drag a copy of an object. Doesn't seem to work now ???
Also, We could hold down the CTRL key and whatever we touched with selection tool would be selected....
Thanks.
This behavior was tweaked for version 9. Now you can drag an object, but before you let go, you can hold the control key (or option) down to make a copy.
The reasoning behind this is that now you have a choice to make the copy or not at the end of the move operation instead of being locked into it.
Matthew GiampapaNNA Technical Support
