Marshall Wright
Arrow at end of added lines
Greetings,
I opened a file last night to make changes to a sheet layer. Opened annotations and deleted some unwanted lines. But when I drew any new lines using the line tool, they all have an arrow on one end, as if I'm dimensioning. And they're blue, which is changeable in attributes.
Any idea how to turn these off?
Thanks,
This could be that your active Class has these attributes set, so when you draw a line with this Class active it will default to those attributes.
Check which Class is currently active when you're drawing the lines and then check the attributes of that Class. Then all should become clear.
You may like to change your active Class or edit the attributes of the currently active Class before drawing the lines. Alternatively you could change the Class of the lines you've already drawn to something else, perhaps None.
