Brick texture turning into stripes
Christiaan
I've been seeing weird directional behavior of textures on nurbs curves. Double clicking the object makes it wake up and turn the texture to the correct direction. I don't know if it's switching from one kind of mapping to another?
Maybe that would help with walls, too.
But that wall treatment would certainly turn some heads...
mk
Looks like the mortar joints are lined up with the side of the other wall, i.e. thay are smearing along the other wall because they are mapped from the side. Is the wall set to the same Planar mapping for all the walls or are they a single object with Planar mapping? You might change it to Auto-Align planar.
