bcd Posted February 17, 2012 Share Posted February 17, 2012 I'm starting a project that will have a significant rendering component. It seems that even without C4D there is an opportunity to pass a VWX file to a Render Farm using Export>C4D. Has anyone had experience/success/issues doing this? Do you have any recommendations for a RF? Pitfalls etc? Thanks k Quote Link to comment
grant_PD Posted February 17, 2012 Share Posted February 17, 2012 I have not used a render farm but it seems like a fairly straightforward process, once you are happy with how it looks in C4D. My usual process when bringing a file into c4d is to adjust textures and texture mapping, adjust lighting. C4D has much more nuanced lighting and texturing options than Vw does. I do a lot of replacing out metals, fabrics and such, for better C4D textures. Then tweak the lighting and prepare it for global illumination if necesarry/warranted. Frame your shots the way you want them to be and specify your output resolution, etc. At that point I would consider the file ready for the renderfarm, as they are really only providing the massive upscale in processing speed that most people don't have. Depending on your requirements I would be happy to take a look at your file and work with you on it. Quote Link to comment
bcd Posted February 17, 2012 Author Share Posted February 17, 2012 Thanks Grant, I'll see how it goes & get back to you. One issue I have is tying up the machine for hours with a render when I can simply farm it out. Quote Link to comment
Monadnoc Posted February 18, 2012 Share Posted February 18, 2012 That's a fascinating idea. I never would have thought of that - using the export as C4D to go directly to a render farm, and skipping actually bringing it into C4D first. That might open up a whole new world of possibilities to someone who doesn't own C4D. I wonder if it would work? And how well/smooth? I'd be interested in hearing about how it went, if you do do it. Thanks. Monandoc Quote Link to comment
