Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Doubledge
Scripting symbol changes
Do any of you scripting gurus know if it is possible to make VW edit every symbol in a drawing and change the pen or fill setting of the symbols components?
Greg
Smart Aleck Answer : Yes.
Longer Answer:
This is untested sudo code. Use with caution.
H1:=FSymDef;
Repeat while H1 <> Nil do
 Begin
   H2:=FInSymDef(H1);
   Repeat while H2 <> Nil do
     Begin
       {Code to do pen settings}
       H2:=NextObj(H2);
     End;
   H1:=NextObj(H1);
 End;
Thanks Pat. I was hoping for that answer. At least it's possible. I've been trying to read up on VS to understand how to do this but there's a bit of learning curve.
I tried your code and I get an error in the first line:
Line #1: H1:=FSymDef;
{ Error: Identifier not declared. }
Greg
Greg,
As I said, that is Sudo Code. Try this, I think it will at least compile. You have to wrap any script that uses variables in a Procedure definition that ends with a Run() statement.
If you use variable you have to declare them in a Var block.
Have you read Robert Anderson's treatise on VS?
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=93218#Post93218
Make sure you try this on a sample or backup file in case there are bugs.
Procedure ModSymbols;
var  H1,H2  :Handle;
Begin
H1:=FSymDef;
While H1 <> Nil do
 Begin
   H2:=FInSymDef(H1);
   While H2 <> Nil do
     Begin
       H2:=NextObj(H2);
     End;
   H1:=NextObj(H1);
 End;
End;
Run(ModSymbols);
Robert's post is great. Thanks for pointing that out.
Your code does compile, thanks. I will dive into the help files to see what I need to add to do the pen settings.
I appreciate your help.
Greg
