Pat Stanford
Select All Lines of Same Length
The following script selects all lines the same length as a selected line.
Procedure SelectSameLengthLines;
{If the first selected object in the drawing is a line}
{this script gets the length of that line and selects all}
{other lines in the drawing that have the same length.}
{February 13, 2012}
{? 2012, Coviana, Inc - Pat Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
Var H1	:Handle;
OLength		:Real;
Procedure DoIt(H2:Handle);
Begin
If HLength(H2)=OLength then SetSelect(H2);
End;
Begin
If GetType(FSActLayer)=2 then
	Begin
		OLength:=HLength(FSActLayer);
		ForEachObject(DoIt,((T=LINE)));
	End
Else AlrtDialog('First Selected Object Must Be A Line.');
End;
Run(SelectSameLengthLines);
Late reply but this came up in a search for some similar functionality. I'm trying to find a way of selecting all lines of shorter length than my first selected line - I tried modifying your script but to no avail (my scripting experience is very very limited!)
Incidentally, I also tried just running it as it is and it did nothing - no errors, no selections, nothing. Also tested it on a circle to see if it would produce the error message but that also produced nothing. Any clues what I'm missing?
Try this:
Procedure SelectShorterLines;
{other lines in the drawing that have a shorter length.}
{September 11, 2015}
{February 13, 2012}
{© 2015, Pat Stanford pat@coviana.com}
{© 2012, Coviana, Inc - Pat Stanford pat@coviana.com}
Var H1	:Handle;
OLength		:Real;
Begin
If HLength(H2)End;
Begin
	Begin
		DSelectAll;
	End
End;
Run(SelectShorterLines);
I changed the comparison in the DoIt routine from = to <.
I also added a DSelectAll function in the main routine so you will only have lines shorter that the original selected at the end, not the shorter lines plus the original line.
