visard 0 Posted February 8, 2012 It seems odd to me that after using this program for so long I still find it difficult to do some straight forward and simple things. For instance, I am working with an old brick house, 1750, the walls are slightly skewed and need to show with a flush brick face from lower to upper floor. It seems that no matter how carefully I place the upper walls to stack above the lower, I still get a line at the floor when rendering in hidden line. Any recommendations for a simple fix? Quote Share this post Link to post
CipesDesign 149 Posted February 8, 2012 Make sure of two things: 1) that the walls are EXACTLY aligned in Plan View. The easiest way to do this is to Copy and Paste In Place on the upper layer. 2) that the top of the lower wall is EXACTLY aligned with the bottom of the wall above. The easiest way to do this is to ensure that the height of the lower wall is fixed and constant, and that the bottom of the upper wall is fixed and constant at that same height. HTH's. Quote Share this post Link to post
CipesDesign 149 Posted February 9, 2012 More important: Did it work? Quote Share this post Link to post
D Wood 1 Posted February 10, 2012 It can be tricky. Sometimes I have had to check the dimensions of every part by adding .0000000 to each dimension (we use metrics here). If you go in and enlarge a junction as far as you can, sometimes there is a incredibly tiny discrepancy, which generates the line. Eliminate the discrepancy and the line disappears. That's why Peter puts EXACTLY in caps! Quote Share this post Link to post
Dieter @ DWorks 24 Posted February 10, 2012 It can be tricky. Sometimes I have had to check the dimensions of every part by adding .0000000 to each dimension (we use metrics here). If you go in and enlarge a junction as far as you can, sometimes there is a incredibly tiny discrepancy, which generates the line. Eliminate the discrepancy and the line disappears. That's why Peter puts EXACTLY in caps! There is a very fast way to correct this: Move the wall away from where it needs to be and move it back to the spot. This works like a charm. Try moving a wall for 0.00002 for example isn't that good and doesn't always happen correctly. So moving it away first then back will work much better. Quote Share this post Link to post
visard 0 Posted February 17, 2012 Thanks all. Actually, no it hasn't worked as yet. I'm wondering if the unit resolution setting has anything to do with the precision of setting objects. For instance, would the stacking improve if the dimension unit resolution was set to .001 instead of .1? Quote Share this post Link to post
Pedro P. Palazzo 1 Posted February 22, 2012 VW used to drive me mad ever since version 12 because of the precision issue. The only way to ensure perfect drawing precision is to, well, max out the precision setting in File > Document settings > Units. I used to think of precision as a kind of distance snap where your drawing would be constrained, but in fact it is not so?you can measure a line, say, 1.25m in a .01 precision level but later find out you drew it at 1.2510045m, for example. So ALWAYS keep your precision set to the highest number of decimals. In VW 2012 the drawing precision can be different from the dimensions' precision. Quote Share this post Link to post
Christiaan 918 Posted February 22, 2012 (edited) In VW 2012 the drawing precision can be different from the dimensions' precision. Thanks for pointing this one out! I finally get to work in high precision without getting mocked by boss (somewhat rightly) for having dimensions with decimal places. Edited February 23, 2012 by Christiaan Quote Share this post Link to post
CipesDesign 149 Posted February 22, 2012 I also, whenever possible, do not draw 'freehand' in VW's. If I want something to be exactly 6'-2" then I type it in. Same goes for moving, rotating, etc. For me it's not hard or time consuming because I'm used to it. But I get files from other people all the time and, well, that's an entirely different story... Quote Share this post Link to post
Vincent C 24 Posted February 23, 2012 (edited) Thanks for pointing this one out! I finally get to work in high precision without getting mocked by boss for having dimensions with decimal places. You can set working units and dimension units with different precisions in the preferences. Very useful in this regard! Edited February 23, 2012 by Vincent C Quote Share this post Link to post
Tim Harland 7 Posted February 27, 2012 I am having this issue with design layer viewports. The walls are copied and pasted-in-place, and work in the base file but when I reference them I get lines appearing between walls - has anyone come across this before? Quote Share this post Link to post
Ride 11 Posted March 5, 2012 (edited) Where are these settings? I don't see where I can set the display precision and the dimension precision separately..... VW2012 SP2 Macbook Pro Edited March 5, 2012 by Ride Quote Share this post Link to post
Christiaan 918 Posted March 5, 2012 File > Document Settings > Units... Quote Share this post Link to post
Ride 11 Posted March 11, 2012 I must be missing something. Whenever I set my precision to 0.000001, the dimensions do the same thing. I have to go and manually change the precision of the dimension after I create it. Is there a way to set the dimensions to an accuracy of 0.1, while the OIP and data bar display 0.000001? Quote Share this post Link to post
John P 0 Posted April 25, 2012 Maybe try a separate file for all your dimensions and reference the drawing info from your main drawing with viewports. Then set main drawing to have precision 0.000001 and the one with your dimensions to have precision 0.1 - wont matter since you are only using this for displaying your dims. Quote Share this post Link to post
Tom Klaber 736 Posted May 2, 2012 You can create dimension styles that should be able to have a set precision value. I would recommend against creating a separate referenced filed for dimensions - you will create a workflow issue as you will have to constantly switch between files when making changes. You can also use the Magic Wand tool to select all dimensions, and then change all the precision display value at one. 3 or 4 click operation. Quote Share this post Link to post
