Vincent C Posted February 1, 2012 Share Posted February 1, 2012 It would be nice if columns would also fall under the 'hide details' function. Quote Link to comment
0 Chris D Posted February 1, 2012 Share Posted February 1, 2012 what font is that...it looks like my old Rotring stencils! Quote Link to comment
0 Vincent C Posted February 1, 2012 Author Share Posted February 1, 2012 (edited) Ha ha that's the whole idea..... ISOCPEUR. I recently discovered the hidden strength of these old 'acad' fonts at an office I work when they decided to go over to Arial completely, when copying and reducing drawings many Arial digits and letters are easily confused with others i.e.. 6,8,9 all look alike, this is a lot less the case with the ISO fonts so I use only those in my own practice now. Edited February 1, 2012 by Vincent C Quote Link to comment
0 Vincent C Posted February 1, 2012 Author Share Posted February 1, 2012 See what I mean: Quote Link to comment
0 Chris D Posted February 1, 2012 Share Posted February 1, 2012 I do see what you mean...I like it. It appears to be an AutoCAD font so it should be supported in DWG exports and PDFs. Quote Link to comment
0 Kizza Posted February 3, 2012 Share Posted February 3, 2012 (edited) Try placing a drawing label, do you get this issue with the above font? I tried using ISONorm and it worked fine i.e. alignment with drawing label was correct. Edited February 3, 2012 by Kizza Quote Link to comment
0 Vincent C Posted February 6, 2012 Author Share Posted February 6, 2012 Nope no problems there..... Quote Link to comment
0 Kizza Posted February 6, 2012 Share Posted February 6, 2012 Your scale text is touching the underside of the line. You can adjust it using the Title and Scale margin and the rule offset though. If you use Arial you won't get the issue of the text touching the line. ICOCPEUR gave me this issue, ISONORM didn't. Quote Link to comment
Vincent C
7 answers to this question
