joey altalef Posted January 30, 2012 Share Posted January 30, 2012 HI! I have a vectorworks 2012 file that contains some pdf images inside. Everytime I try to export it to DWG, the pdfs disappear. Is it a bug from VW2012? any ideas?? thanks!! joey Quote Link to comment
VincentCuclair Posted January 30, 2012 Share Posted January 30, 2012 The pdfs will probably be converted to pngs or bitmaps that must lie in the same place as the dwg to be visible. Quote Link to comment
joey altalef Posted January 30, 2012 Author Share Posted January 30, 2012 thats what I thought.. but it doesnt work... I had to export the file to VW2010 and do there the export to DWG... Quote Link to comment
RickR Posted February 5, 2012 Share Posted February 5, 2012 You can convert (cntl-K) a PDF. You get a rectangle, a bitmap and/or lines, depending on how the PDF was made. Then it should export fine. Quote Link to comment
joey altalef Posted February 5, 2012 Author Share Posted February 5, 2012 thanks!!! I had no idea you could convert a PDF to lines! Quote Link to comment
