creating a flat pattern for a frustum (a truncated cone)
I need to flat pattern a 3-d frustum so that it can be replicated in paper for a white model. Once I have the frustum created in VW, how can I break it into surfaces and get the curved portion to lay flat? (Once I get that far, I can change the object to a polygon, and use that as my paper pattern.)
  • 1 month later...
I needed to make a 4-foot tall paper cup.
I made the cone using the cone tool. (You can also use make a tapered extrude) I chopped off the pointy end using the split tool.
Convert to Nurbs.
Ungroup.
Unfold surface (in the 3d power pack)
And voila, I have the patterns for the cup.
hello all,
is think its time that there is a competition for the most original and unconventional use of VWs.
categories could be >>> puppet houses, food design, miscellaneous and and and
the winners get a coffee mug from NEMETSCHEK
peter
Edited by go2greece
