FunkyBass Posted January 28, 2012 Share Posted January 28, 2012 I don't know wether it's even possible, but I'd like to get the scaling factor of symbols in a worksheet. Any suggestions? 1 Quote Link to comment
Miguel Barrera Posted January 30, 2012 Share Posted January 30, 2012 I believe by definition, symbols do not have different scales. In vw 2012, if drawn in paper units, symbols will always look the same size on print and its scale will be the same as the layer or viewport they belong to. If drawn in world units, which was the only type in older versions, the scale is always 1:1 and how they appear on paper (smaller/larger) depends on the layer or viewport scale. Quote Link to comment
bcd Posted January 30, 2012 Share Posted January 30, 2012 Symbol behavior has been enhanced to allow Symmetric & Asymmetric scaling. There must be a way to pull the scale factors but I can't find it right now. Quote Link to comment
Pat Stanford Posted January 31, 2012 Share Posted January 31, 2012 I don't think you can get symbol scaling directly in a worksheet. It is available in Vectorscript, so you could use a script to write the data to a record attached to the symbol and then bring that into the worksheet. But then you would have to remember to run the script every time you need to update the info in the worksheet. Quote Link to comment
hmart Posted January 18, 2019 Share Posted January 18, 2019 (edited) Has this changed since 2012? I like to use tree symbols and scale them. Our local reg's dictate how close you can build near "protected" trees and I like to scale the symbol based on the formula dictated by the city (and then I populate the required tree table based on these symbols) BUT, I have to manually enter data (tree diameter) because I can auto-populate the symbol scaling factor... Edited January 18, 2019 by hmart Quote Link to comment
GatRed Posted January 4 Share Posted January 4 Hi, I need this command to get quantities… @Pat Stanford, I don’t know how to do script in Vectorworks… Can you help me to make a script that get scale factors of a symbol please ? Thanks !!! Quote Link to comment
GatRed Posted January 4 Share Posted January 4 I’ve found your response here Thanks a lot @Pat Stanford ! Quote Link to comment
