MikeN
Opening Files....
When using Crtl+O or File>Open to open a file within VW, the default folder is never the same. For instance, if I've opened and am working on ABC.mcd in folder 'X' and I want to open 123.mcd in the same folder, VW frequently defaults to a random folder to open a file from. Is there a way to set a default foler for opening VW files?
VWA 9.5.1Win XP Pro
Under Windows XP you should be getting this behavior. Every time you open the program, VectorWorks should default to your default OS wide open/save location.
Once you are within a session of the program, VectorWorks will remember the last folder you were working in, but if you quit and reopen VectorWorks that will get set back to the default.
Matthew GiampapaNNA Technical Support
