pinkystink Posted January 20, 2012 Share Posted January 20, 2012 Hi There I have worked on VW for 15 years (minicad to start with) But for many months now I am baffled with what is a very simple modelling issue. Basically If I want to create a rectangle with curved corners, I normal drawing rectangle with the tool "rounded rectangle tool" then extrude. Once I import this to Art it should be solid, however, its isn't just an outline. I have got round this issue by producing the same shape by "subtracting solids", but it is a long way round and a time wasting modelling process. Prior to VW2010 I never had this issue I would very much appreciate help as it slows done my work flow massively...anyone else had this experience? Please help, thanks Running on iMac (2009 2.8ghz Intel 4GB - Lion OS (it was like it before I upgraded to new OS) Quote Link to comment
mike m oz Posted January 20, 2012 Share Posted January 20, 2012 Is your extrude solid in Vw? ie. does the 2D source shape have a fill? An alternative method would be to extrude a Rectangle and then use the Fillet Edge tool (3D Modeling toolset) to round the required edges. Quote Link to comment
pinkystink Posted January 20, 2012 Author Share Posted January 20, 2012 thanks Mike Yes it is solid in VW and "filled" Thanks for alternative way that is easier then subtract solid and punching the curves and does work. But I just can't understand why this issue is there in the first place, maybe its just my system some weird bug, it doesn't happen on the normal rectangle shape when extruded so its to do with the curves. Thanks again Quote Link to comment
mike m oz Posted January 20, 2012 Share Posted January 20, 2012 The fact the 'Rounded Rectangle' extrude is solid in Vw but not in Artlantis suggests that there is a glitch in the import to Artlantis. Perhaps try it with a file that contains only 'Rounded Rectangle' extrudes and if the problem is still there in Artlantis bug submit it to them. Quote Link to comment
pinkystink Posted January 20, 2012 Author Share Posted January 20, 2012 thanks, have tried just that and will do as suggested. Its hard to know where the fault lies which Software but if other users aren't experiencing it on VW then it must be ART. Thanks so much Quote Link to comment
pinkystink Posted January 20, 2012 Author Share Posted January 20, 2012 Arh I get an error message when it exports: One facet or more in this file contain more then 1000 vertices artlantis cannot handle such vertices they were not....???? Doesn't end sentence Can you explain Quote Link to comment
pinkystink Posted January 20, 2012 Author Share Posted January 20, 2012 Right I am going to answer my own question here! Basically some one off the Art forum kindly suggested I reduce the export conversion rate from very high to high, did it, did the trick... Job done!! I will test to see how exporting on a low rate will effect modelling There is always a simple answer, just need to stop flapping!! Thanks for help :-) Quote Link to comment
