Craig D.S. Posted January 13, 2012 Share Posted January 13, 2012 (edited) Greetings I an working in 1:1 scale an the Space Lables are only dots I was able to do it with a section marker, but can't find how to change the Space Lable Text Size or even scale the lable. Is there anyway to increase thr size of the marker and or text? thanks Craig D.S. Edited January 13, 2012 by Craig D.S. Quote Link to comment
bcd Posted January 13, 2012 Share Posted January 13, 2012 Edit their symbol definitions in the Resource Browser. Quote Link to comment
Mitch Brooks Posted January 14, 2012 Share Posted January 14, 2012 BCD is right but to elaborate a bit: The label in a Space is a symbol. You can choose alternate symbols, if they are in the Symbol folder, or make your own up. It is not a completely straight-forward process but allows you to use different labels for spaces within a file. You may want one for smaller tighter spaces for instance, or different ones to show different information. HTH. Quote Link to comment
Farookey Posted January 16, 2012 Share Posted January 16, 2012 Hi... Also... When editing these in a document (at least in VW2011), ensure that you are either on a 1:1 scaled design layer, or a sheet layer at the time of edit. It is not advised that you edit the symbol(s) whilst on a scaled layer as you may get some unexpected results. :-) Quote Link to comment
Craig D.S. Posted February 9, 2012 Author Share Posted February 9, 2012 Thanks all for responding, it is very helpful Quote Link to comment
