How do I create a lawn area for 3D?
JedPLM
Jed, There are many ways to do this. For anything other than a fairly flat area I usually create a Site Model based on topography from a survey. For a simple flat lawn/yard you can use a Floor Object or even a simple Extrude. For sloping in one direction only you can use a Roof Face. A grass Texture can be applied to any of the above. BTW, it's generally a good idea to list your VW's and OS info (My Stuff pulldown above; Edit Profile; Signature).
Jed - Can't tell your experience from your post, but here are some basics just in case
Textures will only apply to 3d objects.
Textures will only be visible when rendered in one of the Renderworks modes or in Open GL (OGL Options need to include Use Textures)
Assign texture to an object in the OIP Render tab >Texture pulldown
Default textures in the list include Nature Grass.
Several ways to make the render, but old faithful is View Menu>Rendering>pick one of these from the list Open GL, Fast Renderworks, Final Quality Renerworks, Custom Renderworks.
Test in a new file containing only a 3d poly or an extrude.
Good luck!
-B
