AEChadwick Posted January 10, 2012 Share Posted January 10, 2012 I have been using VectorWorks for years, but I am a dreadful novice at Vectorscript. Here is my attempt to create a title block that auto-updates using information from its own filename. To explain? I always name files in the same format, with all files for a single show living in their own folder. ie., SHOW FOLDER : SET-EPISODE-Name.vwx So a complete string might be DexterS6 : 862-612-Int Modest House.vwx means "Dexter" Set #862 for Episode 612, "Interior Modest House." Sometimes the names vary slightly, like Torchwood : AMORT-ALL EPISODES-FBI Headquarters.vwx means "Torchwood" Permanent (amortized) Set, "FBI Headquarters." But it's always simply strings separated by hyphens. (ie., the set "numbers" are for reference?they are not part of any calculation, so they're not integers.) My title block is a dead simple line of text?really it?s little more than the most essential information, please see the attached file. Below is my attempt to script the named stamps? Needless to say, my work is little better than pseudocode, and does not compile cleanly! I hope some VectorScript genius can lend a hand! I will credit you & praise you in the final script, which will be handed down into posterity. ?? { //////////////////// TitleBlock Stamper Modified from Scripts by Sakkinen & David LaBarbera and using 'Txt-Extract char separated' from www.vectorlab.info //////////////////// } FUNCTION StampIt(VAR textObjectName: STRING; stampString: STRING): STRING; BEGIN textH := GetObject(textObjectName); IF textH = NIL THEN BEGIN Sysbeep; AlrtDialog('You must have a text block named ' & textObjectName & ' for this command to work!'); END; SetText(textH, stampString); { //////////////////// } FUNCTION ExtractCharSep(VAR str: STRING; ch: CHAR): STRING; VAR posStr?: INTEGER; BEGIN ExtractCharSep?:= ''; { char sep at start deleted } WHILE (Len(str) > 1) & (Pos(ch, str) = 1) DO str?:= Copy(str, 2, Len(str)); IF Len(str) > 0 THEN BEGIN posStr?:= Pos(ch, str); IF posStr > 0 THEN BEGIN ExtractCharSep?:= Copy(str, 1, posStr-1); Delete(str, 1, posStr); END ELSE ExtractCharSep?:= str; END; END; { //////////////////// } Procedure StampDL; VAR textH : HANDLE; stampString : STRING; dateValue, docName, setNumber, episodeNumber, setName : STRING; BEGIN docName := GetFName; setNumber := ExtractCharSep(docName, '-'); episodeNumber := ExtractCharSep(docName, '-'); setName := ExtractCharSep(docName, '.'); dateValue := Date(1, 1); {Date ( [0=Full, 1=Abbrev, 2=Short], [0=Date, 1=Date & Time, 2=Time]) } stampIt('Set Stamp', setNumber) stampIt('Episode Stamp', episodeNumber) stampIt('Name Stamp', setName) stampIt('Date Stamp', dateValue) END; RUN (StampDL); Quote Link to comment
Pat Stanford Posted January 10, 2012 Share Posted January 10, 2012 Try this one. Several issues in fixing it, overall not a bad first crack. { //////////////////// TitleBlock Stamper Modified from Scripts by Sakkinen & David LaBarbera and using 'Txt-Extract char separated' from www.vectorlab.info //////////////////// } Procedure StampDL; VAR textH : HANDLE; stampString : STRING; dateValue, docName, setNumber, episodeNumber, setName : STRING; Procedure StampIt(textObjectName: STRING; stampString: STRING); BEGIN textH := GetObject(textObjectName); IF textH = NIL THEN BEGIN Sysbeep; AlrtDialog(Concat('You must have a text block named ', textObjectName, ' for this command to work!')); END; SetText(textH, stampString); End; { //////////////////// } FUNCTION ExtractCharSep(VAR str: STRING; ch: CHAR): STRING; VAR posStr : INTEGER; BEGIN ExtractCharSep := ''; { char sep at start deleted } WHILE (Len(str) > 1) & (Pos(ch, str) = 1) DO str := Copy(str, 2, Len(str)); IF Len(str) > 0 THEN BEGIN posStr := Pos(ch, str); IF posStr > 0 THEN BEGIN ExtractCharSep := Copy(str, 1, posStr-1); Delete(str, 1, posStr); END ELSE ExtractCharSep := str; END; END; { //////////////////// } BEGIN docName := GetFName; setNumber := ExtractCharSep(docName, '-'); episodeNumber := ExtractCharSep(docName, '-'); setName := ExtractCharSep(docName, '.'); dateValue := Date(1, 1); {Date ( [0=Full, 1=Abbrev, 2=Short], [0=Date, 1=Date & Time, 2=Time]) } stampIt('Set Stamp', setNumber); message(setNumber); Wait(1); stampIt('Episode Stamp', episodeNumber); message(setNumber); Wait(1); stampIt('Name Stamp', setName); message(setNumber); Wait(1); stampIt('Date Stamp', dateValue); message(setNumber); Wait(1); END; RUN (StampDL); Quote Link to comment
AEChadwick Posted January 10, 2012 Author Share Posted January 10, 2012 Hey Mr Stanford! as if I wasn't in your debt already! Thank you so much for checking in. Your version worked perfectly! I shall now set about complicating it, and I will check back in as soon as I have broken something. ? Quote Link to comment
Ajychau Posted July 5, 2012 Share Posted July 5, 2012 Hey Guys, This is awesome! I just modified it slightly to help with tracking printed documents! Our template now has your script sitting in there! Cheers! Quote Link to comment
