Steve B. Posted January 2, 2012 Share Posted January 2, 2012 (edited) Just upgraded from 2009 to 2012, using LW5 as well In '09, in order to keep track of used and no-longer-needed xml files, I had created a desktop folder where I would send my xml files from VW and where to look in LW. 2012 seemingly does not like this. When I save the xml, using other location (then where the VW data file is stored), the LW file can't read it and I get the "You need to doan export in VW error in the LW window, If I choose to have VW save the xml in the same folder/file location as the VW data file, LW sees the xml with no problem. Is this a LW issue or a VW issue ?. Seems like a VW as the xml exchange from a different folder works fine in 2009. Steve B. Edited January 2, 2012 by Steve B. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 2, 2012 Vectorworks, Inc Employee Share Posted January 2, 2012 Steve, This was a problem with Vectorworks 2012 that was resolved in 2012 sp2. If you are using 2012sp2 and still having the problem please let us know. Quote Link to comment
Steve B. Posted January 2, 2012 Author Share Posted January 2, 2012 Ah, Ye Olde SP2 !. That did the trick, Thanks Kevin Quote Link to comment
