string dialog box question
michaelk
I must be reading right past this in the function reference and not seeing it. There is a CreateEditText() but no SetEditText or GetEditText. And the GetEditText idea can't be right because DialogResult is an integer...(does it have to be?)... confused.
Can someone help me out with the correct functions for a dialog box that gets a user string?
This is what I expected it to be but with nonexistent functions:
Thanks
mk
Procedure TextDialogQuestion;
{Badly scripted by Michael Klaers}
VAR
DialogID :INTEGER;
DialogResult :INTEGER;
userString : STRING;
PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT);
BEGIN
CASE item OF
SetupDialogC:
BEGIN
Set[EditText?](DialogID,4,DialogResult); {....what really goes here?}
END;
1:
BEGIN
Get[EditText?](DialogID, 4, DialogResult); {....what really goes here?}
userString := DialogResult;
END;
END;
END;
BEGIN
DialogID := CreateLayout('Get User String', FALSE, 'OK', 'Cancel');
CreateEditText(DialogID,4,'enter text here',24);
SetFirstLayoutItem(DialogID, 4);
DialogResult := RunLayoutDialog(DialogID, Dialog_Handler);
Message('User Entered String is: ',userString);
END;
RUN(TextDialogQuestion);
Charles
I saw that but got scared off by this:
Declaration:
PROCEDURE SelField
( fieldID:INTEGER ) ;
Special Notes:
SelField is obsolete as of Vectorworks 2010
That's the function I want, but I can't find the replacement.
mk
whoops. Copied the wrong one.
I ment to quote this:
Declaration:
PROCEDURE SetField
( fieldID :INTEGER;
str :DYNARRAY[] of CHAR
Special Notes:
SetField is obsolete as of Vectorworks 2010
Edited by michaelk
One more question about this dialog box.
This is probably me not understanding how a dynamic array of CHRs works....
This script functions (pretty much): [thank you, ccroft]
VAR
DialogID :INTEGER;
BEGIN
CASE item OF
SetupDialogC:
BEGIN
SetItemText(DialogID,4,userString);
END;
1:
BEGIN
GetItemText(DialogID, 4, userString);
END;
END;
END;
BEGIN
END;
What it doesn't do is put the default string value 'enter text here' into the text dialog box.
Any suggestions? I'm trying to pick up an existing value, display it in the dialog box and keep it if the user doesn't change that field.
thanks
mk
Michael,
When your program starts, userString is uninitialized. When your dialog starts, the first thing that happens is you write userString into field 4, thus overwriting the starting value of field 4 with a null string. In the code below, I removed that one line in the SetupDialogC section and it runs with your initial text string displayed in the field.
HTH,
Raymond
VAR
DialogID :INTEGER;
BEGIN
	CASE item OF
		SetupDialogC: BEGIN
		END;		{ SetupDialogC }
		1: BEGIN
		END;		{ 1 }
	END;		{ case }
END;		{ Dialog_Handler }
BEGIN
CreateEditText(DialogID, 4, 'enter text here', 24);
Message('User Entered String is: ', userString);
END;
Thanks!
Is there a discussion in any reference of SetupDialogC?
Searching the function reference reveals that it is mentioned 17 times, but only in examples of other functions.
The language guide lists it 3 times, but always while discussing other topics. It's not a "topic" anywhere I can find.
Is there also a SetupDialogA and SetupDialogB? Or does C refer to the language of the SDK?
Thanks for your patience, everyone.
mk
I always thought of the C as standing for "Constant". Statements in this section are executed BEFORE the dialog is presented to the user. Do all of your setup here. There is also a SetdownDialogC. Statements in this section are executed AFTER the dialog is closed by the user. I don't know if you'll ever need SetdownDialogC, but it's there for completeness.
Raymond
Raymond
Where did you find SetdownDialogC?
I can't find it in the function reference or the language guide...
I'd love to see a discussion of exactly what variables are set and what functions are executed in what order with SetupdialogC and SetdowndialogC.
Currently, I'm using the "try this and see if it works" technique... :-)
thanks again
mk
SetUp/DownDialogC are predefined constants. You can think of them like pi -- you can use "pi" in your script, or you can use "3.14159," but using the constant is much easier and clearer.
You are right that there is not much documentation. I learned them from a listserve discussion a while ago, which predated even seeing the constant in examples. After a quick search, the only documentation I could find is in the SDK in VectorScript Reference.xml:
SUDC: predefined constant value that is passed to the dialog event handler subroutine when a modern custom dialog is initially displayed onscreen.[[bR]][[bR]]This constant is usually used to determine when to execute dialog initialization and setup calls
SDDC: predefined constant value that is passed to the dialog event handler subroutine when a modern custom dialog is dismissed.[[bR]][[bR]]This constant is usually used to determine when to execute dialog cleanup calls prior to exiting the dialog
If you step through a debugger, you can see these values of the item variable. You could just use those values in your case statement, but using the constants is much clearer.
So to directly answer your question -- the variable item (as per the examples) is set to these constants by RunLayoutDialog on the first and last pass through your handler, respectively. No functions get run automaticaly, only what you specify in your handler statement.
HTH,
Josh
Raymond
Hi Michael,
???To be honest, I guessed. It's one of the few times I took a shot in the dark and hit it on the first try. Saddly, I have never needed SetdownDialogC.
???As Joshua said, nothing happens during these dialog events that you don't explicitly program. They are just 2 events that get passed to your handler to start things up and finish them off. No magic involved. If you don't put any code in these sections, the dialog will run as if they never existed.
Raymond
That is an insightful and prescient guess!
Thanks, Raymond. I'm slowing figuring it out... Until your reply above prompted me to watch the debugger, I was unclear about when SetUpDialogC executed in relation to the rest of the code.
It would be nice if there was more documentation. And if the examples didn't involve obsolete functions!
thanks!
mk
