beanus Posted December 20, 2011 Share Posted December 20, 2011 since installing version 2012 I'm having problems with the number of prints vctorworks produces, if I tell it to print a single copy I get one copy but if I try to print two copies I get four copies and so on - any one else had a similar problem. The plotter I use is a Designjet 500. This problem only happens with vectorworks. Also when GDI+Imaging is turned on I can only print a single copy whatever number I try to print. Quote Link to comment
Bryan G. Posted December 21, 2011 Share Posted December 21, 2011 have not experienced this. I also have a 500. I will play with it and report back. Are you printing from Design Layer or Sheet Layer? Quote Link to comment
mcochran Posted December 21, 2011 Share Posted December 21, 2011 I am having problems getting drawings to print to designjet 500 from VW2012. One particular drawing refused to print at all and would eventually crash VW. I removed some of the geometry and it is printing now however it took about 20 minutes. I have not had these issues in the past. Windows 7 pro 64 Quote Link to comment
John Meunier Posted December 21, 2011 Share Posted December 21, 2011 A work around might be to print to PDF first. Then print the PDF file to the Designjet500. Quote Link to comment
