  • 1
grant_PD
Class and Layer Mapping, Prefixes and Export
I have a drawing I'm trying to organize. There is a huge class root that I would like to add the prefix "z-" to, so that it drops to the bottom of the class list. Is there a way to do this without going through each one individually?
12 answers to this question
This can be done as part of "Import DWG". But I don't know of a way to do it in a native VW's file. One thing that may save some time is, as you are changing the first class, copy the "z-". Then in all subsequent classes all you need to do is double click to open, click cursor to beginning, hit command/control-V, then hit return key...
Grant, I thought of a script. But then I thought that the script would need to include a list of all the classes that get the prefix. Then I thought that the time it would take to write the list is probably about the same as the time it would take to open and change each one... I guess that's why we call it work!
Have a look here
http://www.vectordepot.com/plug-ins/
Prefix Classes
I used to use this when importing dwg files back in VW 11 and 12 I think
Just installed it in VW 2012 and it seems to work - be careful
Copy your workspace maybe and try in a file that is not important
Would be good if a VS genius could re write this and provide a dialogue you could choose the classes to add the prefix too
Unless of course if there is an existing way
Edited by Ozzie
I've downloaded it and will give it a try, thanks!
VS seems to be a major opening for a lot of the menial tasks that the average user wants to do. It's a shame that it's a scripting language, and not a graphical language. There's a language in C4d called xpresso I think, that one can program using flowchart style icons. That would be very very cool.
Hello. This string was back in 2011. Has anything been added to 2015 or previous to enable this? I can't find anything.
Thanks
by the way, I can confirm the plugin works for 2015, but applies to all classes in the document only (apart from the dimension class)
I know this post is old, but I'm wondering if this was ever a feature that was added to the wish list? The link in the previous post no longer works. I'm having to import a load of mapping data and DWGs and this would help me tidy up the large amounts of classes rather than going though them individually?
I did a few times.
German localized Version has such a tool.
Not just adding prefixes but also renaming options.
