simetz Posted May 18, 2002 Share Posted May 18, 2002 I use VW to design furniture and currently only use layers, not any non-default classes. I have also recently converted from MAC to PC. I am running 9.0.1 but have also installed the 9.5 update. When I work on one of my imported Mac (from Minicad 7) files I can have numerous visible grayed and invisible layers on a drawing. When I start a new file even if I go into layers and make all layers visible, only the active layer is visible and prints, all others are grayed. Any help would be appreciated. Thanks simon@simonmetz.com Quote Link to comment
MullinRJ Posted May 19, 2002 Share Posted May 19, 2002 It sounds like your layer options are set to "Gray Others". Make sure you at least have "Show Others" selected. It is in the "Organize" menu under "Layer Oprions...". Raymond Mullin Quote Link to comment
