WhoCanDo Posted December 14, 2011 Share Posted December 14, 2011 Hi, Since BeginDialog is comming to its end, I want to try and convert my macros to CreateLayout but I can't find much help or examples. With the below, what is the next step to identify which box is checked? procedure test; var i, OI : integer; DialogID : longint; procedure Dialog_Handler (var a : longint; b : longint); begin end; begin DialogID := CreateLayout ('CHOOSE', False, 'OK', 'Cancel'); CreateStaticText (DialogID, 3, 'Choose !', 30); SetFirstLayoutItem (DialogID, 3); for i := 4 to 6 do begin CreateThreeStateCheckBox (DialogID, i, Concat (' ', i)); SetBelowItem (DialogID, i - 1, i, 0, 0); end; if (VerifyLayout (DialogID)) then If (RunLayoutDialog (DialogID, Dialog_Handler) = 1) then begin SetThreeStateCheckBoxState (DialogID, 4, 1); for i := 4 to 6 do begin GetThreeStateCheckBoxState (DialogID, i, OI); message (OI);wait(0.5);clrmessage; end; end; end; run (test); Quote Link to comment
maarten. Posted December 14, 2011 Share Posted December 14, 2011 Message inside a dialog run will not work. So, the way to get temp information from your dialog while it's running is to use the Debugger (but chances are big that VW will crash) or to put the info into text objects. in short: after you create your layout with CreateLayout, you need to create controls and set them on the correct place with SetFirstLayoutItem, SetBelowItem, SetrightItem, SetFirstGroupItem,... (but you already did that part correct) Then you run the dialog with RunLayoutDialog. This Function will call the Dialog_Handler Procedure. In that Procedure, VW will tell you what control has been modified by the user (you called that Var a). At creation of the dialog, so as first, SetupDialogC will be called. In the SetupDialogC case, you can adjust your controls (visibility, enable, disable, check, uncheck,...) And then you have the 1 case (user clicked OK button) and the 2 case (user clicked Cancel button). procedure test; var i, OI : integer; DialogID : longint; procedure Dialog_Handler (var a : longint; b : longint); begin case a of SetupDialogC: begin SetThreeStateCheckBoxState (DialogID, 4, 1); end; 1: begin for i := 4 to 6 do begin {get the information from your dialog} GetThreeStateCheckBoxState (DialogID, i, OI); {this is temp, jus tto show the information} MoveTo(0,i*-2cm); CreateText(Concat(i,': ',OI)); end; end; end; end; begin DialogID := CreateLayout ('CHOOSE', False, 'OK', 'Cancel'); CreateStaticText (DialogID, 3, 'Choose !', 30); SetFirstLayoutItem (DialogID, 3); for i := 4 to 6 do begin CreateThreeStateCheckBox (DialogID, i, Concat (' ', i)); SetBelowItem (DialogID, i - 1, i, 0, 0); end; if (VerifyLayout (DialogID)) then If (RunLayoutDialog (DialogID, Dialog_Handler) = 1) then begin {place the rest of your script here} end; end; run (test); Quote Link to comment
Miguel Barrera Posted December 14, 2011 Share Posted December 14, 2011 Message inside a dialog run will not work. So, the way to get temp information from your dialog while it's running is to use the Debugger (but chances are big that VW will crash) or to put the info into text objects. VW will always crash if you attemp to open another window while a dialog is executing, so even the debugger will not work because it is also a window. The safest method I found is to "Write" the results to the output or open file. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 16, 2011 Vectorworks, Inc Employee Share Posted December 16, 2011 A great way to show messages while in a dialog is to add a static text "message" field in the dialog itself and load it with whatever you wish while in the dialog loop. Quote Link to comment
