shr Posted December 1, 2011 Share Posted December 1, 2011 I am trying to create a lighting schedule with VA schedules. It has been successful so far with single storeys, but now I have a double storey building, it is only referencing the objects on the ground floor. Any suggetions? Quote Link to comment
Pat Stanford Posted December 1, 2011 Share Posted December 1, 2011 Edit the worksheet database criteria and see if it is specifically showing only that layer. If it is, then edit the criteria to include all the layers of interest. Quote Link to comment
shr Posted December 1, 2011 Author Share Posted December 1, 2011 My database header says =('Equipment Record'.'ID') only. I try to add criteria and I get this =('Equipment Record'.'ID')((L='Design Layer')) instead of the ID for each object Quote Link to comment
Pat Stanford Posted December 1, 2011 Share Posted December 1, 2011 That is not the database criteria, that is the column formula. 1. Make sure that the database header row (3 not 3.1, 3.2, etc) is visible. 2. Right click on the row header for the database row. 3. Choose Edit Criteria. 4. Use the dialog box that opens to view and modify the criteria. Quote Link to comment
shr Posted December 1, 2011 Author Share Posted December 1, 2011 Good, Thanks. This was confusing and not explained in help. Quote Link to comment
