DTM Line Control
gbland
4 answers to this question
I think you can do this now. Take a look at the attached screenshot and let me know if that's more or less what you're after. If so, you can do it by going into the Site Model Settings and changing the Graphic Properties as desired. I have also attached a shot of the settings I used. The only thong I had to do 'manually' was to add the topog elevation numbers for the proposed (changed) lines, as they don't really show up clearly otherwise.
