Love that Extrude Along Paths can be co-planer. Crowns on gable rakes are simple now when they used to be too much trouble to bother. However, I'm still longing for Julian Carr's 3D manager. Here is a list of things it could do 10 years ago that current EAP's can not do but should.
- multiple objects per extrude
- class settings of each object determine texture allowing for multiple textures in one extrude
- Symbol based profiles allowing for sharing of profiles easily between files through the Resource Browser and the creation of default libraries of common profiles. Also allowing for quick reference to a profile when you want to create another identical EAP that just has a different path.
- and I might still be able to make some progress on the technique here but in 3D manager I would be able to keep the origin of the profile and path common with the overall file. When I had 6 different objects that had different paths but identical profiles I could just draw the new path and cut and paste it into a duplicate of the symbol(3D manager) or now the EAP object and regenerate. The new object would show up exactly where expected. Unique origins for EAP's make this impossible.
- rotation and orientation seemed to be very predictable. I'm constantly flipping and rotating in the EAP to get what I need.
I may have some things to learn still on this but it would be nice if I could match the origin of the path object to the overall drawing origin so I can cut a path drawn in the drawing into the path setting of the EAP and have the object show up in the right place.
I also can't stand the origin of the profile defaulting to the center of the profile object. It would be nice if I could select a locus point in addition to my profile and the EAP would assume I want my origin at the locus point. Never do I control the final location from a center point but some offset distance which means I always have an additional edit for final location both for path location on the drawing and for profile orientation to that path. Neither should be necessary.
Joe
