alfie hope Posted November 18, 2011 Share Posted November 18, 2011 Has anybody has any trouble with trying to get x-references to come through into viewports? I have some contours that i need on my site plan and they come through just fine in the design layer... I've checked that the correct layers/classes etc are turned on, can anybody help?? Alfie Quote Link to comment
Chris D Posted November 18, 2011 Share Posted November 18, 2011 Alfie, please add a signature showing your VW version, platform, machine etc. You don't even say which version of VW you are talking about. Design Layer ViewPorts (xrefs) have this problem on VW2008 for sure, don't know about later versions. The DLVP appears fine, but when you put it on a sheet layer viewport the DLVP keeps disappearing. The trick we have to use is to go to the design layer that the DLVP is referenced into, go to View>Standard Views>Top/Plan (or use the keyboard shortcut), then go back to the sheet layer and it will magically show up. Quote Link to comment
bcd Posted November 19, 2011 Share Posted November 19, 2011 Select the Sheet Layer Viewport and click Project Screen Objects in the OIP. Quote Link to comment
