Assembly Posted October 25, 2011 Share Posted October 25, 2011 Is there a way to script the drawing environ set up. I have a 27inch Cinema for my Laptop in the Office. For ever moving the pallets around to adjust for screen size. I'd like to script a reposition of my pallets. Quote Link to comment
CipesDesign Posted October 25, 2011 Share Posted October 25, 2011 You can do this with two discreet workspaces. Start on the smaller screen (b/c if you do it the other way palettes can get "lost" outside the viewable area). Quote Link to comment
VincentCuclair Posted October 26, 2011 Share Posted October 26, 2011 (edited) A big problem with this is that you need to 'anticipate' what workspace you are going to use next time......ie. if you've been working in the 24" the last time and you open VWs on a 17" the next time you've destroyed the 24" setup..........and every change to a workspace subsequently needs to be done in each i.e.. shortcuts etc. Justin, there was a thread/wish list on this a couple of years ago in which someone suggested using 2 desktop icons one for each screen size + a little fiddling in some preference files, try searching for that.......not icons but automator..... Edited October 26, 2011 by Vincent C Quote Link to comment
VincentCuclair Posted October 26, 2011 Share Posted October 26, 2011 Found it! Here are some solutions: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=90106&Searchpage=1&Main=19198 http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=26813&Number=129895#Post129895 Quote Link to comment
Assembly Posted October 30, 2011 Author Share Posted October 30, 2011 Thanks... I suspect this is a common case for 1000's of users. Come on VW do we really have to get into shell scripts to solve such a case. Quote Link to comment
