bjoerka Posted October 20, 2011 Share Posted October 20, 2011 (edited) Hi, i have a problem with section viewports, more with the drawn section lines in the top/plan view in my model. what i did... - draw a section line - name the section - as destination i selected a sheet layer - i arranged 8 section viewports on the sheet layer. to each section viewport a rectangle as crop object is added after the section viewport shows up on the sheet layer - in the 3d plan (design layer) i have drawn a rectangle as viewport border for the topview - after setting the destination to the same sheet layer as the viewport sections, i can not see the section lines that are drawn in the design layer. - the classes are set visible in the viewport any hints what?s going wrong here? thanks. bjoerka -- macbookpro osX.6.7, vw 2011 sp4 Edited October 20, 2011 by bjoerka Quote Link to comment
Pat Stanford Posted October 20, 2011 Share Posted October 20, 2011 Select one of the section viewports in the Object Info Palette (OIP) and scroll down to the bottom, You will see a button labeled Section Line Instances (or something like that). Click the button and you will get a dialog box that will let you pick the layers and viewports the section line for that viewport is visible in. Quote Link to comment
bjoerka Posted October 21, 2011 Author Share Posted October 21, 2011 Yep. You did it! Thaks a lot for the quick help! Best from Stuttgart , bjoerka Quote Link to comment
