Screen Plane Layer Plane Switching
Hi,
I've the Problem that Groups can't be switched from Screen Plane to Layer plane
I'm working with some Template FIles from our Venue that are created with Versions before Layerplane was introduced, and almost every Symbol contains
Groups. there are a whole lot of them.
Is there a way to convert these Symbols to accept LayerPlane without editing every Symbol and search for Groups?
Horst M.
Edited by Horst M.
  • 3 years later...
Hallo,
I had Contact with the Author of the Scripts.
Here is his response:
The scripts work in 2014 and earlier, but not in 2015. According to the VS documentation (http://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#miscpref), the relevant object variable (1160) has not been changed, so there is no explanation and no fix that I can implement.
If you wish, you have my permission to post the scripts there as there is no secret code in them. Someone might know what is going on.
PROCEDURE Objs2LayerPlane; { © Petri Sakkinen 2010 }
PROCEDURE DoIt (h : HANDLE);
BEGIN
SETOBJECTVARIABLEBOOLEAN(h, 1160, FALSE);
END;
BEGIN
FOREACHOBJECT(DoIt, ALL);
END;
RUN(Objs2LayerPlane);
PROCEDURE Objs2ScreenPlane; { © Petri Sakkinen 2010 }
BEGIN
SETOBJECTVARIABLEBOOLEAN(h, 1160, TRUE);
END;
BEGIN
END;
RUN(Objs2ScreenPlane);
Best regards,
It would be nice if someone from NEM could have look, as it seems to bee some
confilct inside of VW.
Regards
Edited by Horst M.
Petri's scripts do seem to work, but at least inside symbols the symbol definition does not update until you edit the symbol. In fact the first time you edit the symbol you won't be able to access the modified objects. Just edit and exit the symbol and you should be OK. If you need to make other changes, just edit it again and all should be well.
Inside symbols now does not offer the Layer Plane option. You now can set the objects inside symbols to Screen Plane, Symbol Definition or Working Plane.
Horst, can you please get this information to Petri since I don't think he follows here any more.
Pat
Ray Mullin has helped work out a workaround for the scripts. The problem appears to be the order that the "geometry" and "symbol header" get reset. If you manually reset the geometry before the header then all is OK. If done in the other order, then you get the weird results.
Revised code for the two scripts follows:
{Modifed 2014, Ray Mullin, Pat Stanford to work with VW2015}
Procedure DoIt (H : Handle);
Begin
	SetObjectVariableBoolean(H, 1160, FALSE);
End;
Function ResetDef(H :Handle) :Boolean;
Begin
	ResetObject(H);
End;
BEGIN
FOREACHOBJECT(DoIt, INSYMBOL & ALL);
ForEachObjectinList(ResetDef, 0, 0, FSymDef);
Sysbeep;
END;
Begin
	SetObjectVariableBoolean(H, 1160, TRUE);
End;
Begin
	ResetObject(H);
End;
BEGIN
ForEachObject(DoIt, INSYMBOL);
ForEachObject(DoIt, ALL);
Sysbeep;
END;
I have the same problem in VW2015 with my PIO's who use this line of code. All PIO worked fine in VW2014 (SetObjectVariableBoolean(H, 1160, FALSE);)
one PIO was a label that we put in walls, when layerlevel is not 0, PIO crashes on this line of code (that sets the PIO itself to the layerplane)
another PIO use an "extrudeAlongPath" I used to set the profile of the extrusion to the layerplane. In VW2015 it crashes (sometimes,...)
SetObjectVariableBoolean (polyh, 1160, False);
extrudeh:=ExtrudeAlongPath(ash,polyh);
its seems a bug to me...
  • 3 weeks later...
  • 5 years later...
