Ian Smith Posted October 8, 2011 Share Posted October 8, 2011 (edited) Hi Group. I'm trying to draw a small building which will eventually be used to create an animation. The building is 3m diameter and very small, but when i use the cylinder or curved wall tool the size of the drawing jumps from 500kb to over 15mb and runs very slow. This happens even when i add just one small curved wall? Tired and frustrated (and working another weekend in York) Help or advice appreciated. Ian Edited October 8, 2011 by displayname Quote Link to comment
bcd Posted October 8, 2011 Share Posted October 8, 2011 Hi Ian, Sorry for your frustration. There shouldn't be a difficulty with a 15mb file. That's on the small side in VW. Perhaps there is an object causing you an issue. Do you have a stairs in there that you can hide temporarily? Did you start with a clean drawing? Can you turn off a bunch of classes or a layer you don't need right now while focusing on what you do? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted October 10, 2011 Vectorworks, Inc Employee Share Posted October 10, 2011 Displayname, try turning off viewport caches. Quote Link to comment
Ian Smith Posted October 15, 2011 Author Share Posted October 15, 2011 Hi Robert and BCD. Thanks for he advice. Got it sorted. Still building the model. Adding trees and hedges at the moment before i set up the animation. Yet another weekend waiting for the animation to generate. Thanks Ian Quote Link to comment
